· Registered
I currently have a 87 Coyote Swapped Coupe W/UPR K Member that has BBK Longtube Headers. I want to switch over to Kooks 1 3/4" Headers,...I have heard conflicting stories as to whether the Kooks Headers will work W/the Mororso Oil Pan. Is anyone currently using Kooks Headers W/Moroso's Oil pan and did you have to do any fab work to make them work together?
· Registered
Thank you very much man. Very clean looking setup you have there. Are you N/A and did the bigger headers hurt you bottom end at all? My tuner actually suggested that I go with the 1 75". I was like Huh? Lol
· Registered
Thank you very much. Yes I'm na but I plan on revving it to 8000+ rpm. On e85. I have a cobra jet intake so I'll lose a little low end to begin with. I'm not worried about it. I plan to run a custom 3" exhaust with custom x pipe and bora xr1 oval mufflers dumped at the axle.
Also my engine is set back 1" now. Not sure how it would affect the upr k member but my team z needed to be clearanced slightly
· Registered
Discussion Starter · #5 ·
Top notch ride man!!! Kooks now makes an X Pipe specific for the coyote swapped headers,...it aint cheap, but a 3 piece easy fit per Kooks. Its advertised on there website. Your car is going to sound absolutely wicked @ 8K.
