1 - 8 of 8 Posts
I have a 99GT. The engine is stock save for pullies and a Timing adjuster. I have been thinking about getting an All Ford EFI kit from NX. I have a couple of questions:
1. How high of a jetting can I get away with on a stock engine?
2. As I said above, I have a timing adjuster. Will setting back the timing take the place of having a chip burned or are there other safety benefits with the chip?
3. Will the use of a window switch help decrease the likelyhood of fuel puddling, or is it simply to keep the motor from overreving?
Any information you could give me would be great. Thanks
1) i would not go past 150 on a modular motor i have seen to many blow up when people get stupid and want more
2) a timing adjuster is a good addtion but you have to remeber your computer adjust your timing so you it help a little but if i were you get a custom burn chip with a 2 bank program one for na and one for nitrous
3) yes a windows switch would help decrease fuel pudding but not by much you are still going to have fuel pudding and a window switch will keep the motor from the driver missing a gear and blowing up the motor
i hope i help you
i hope i help you
If you have the NOS come on at 3000+RPM there is no way in hell it will puddle!
1. 150 max and that is pushing it IMO
2. Set the timing back to stock and run 93 when spraying...and if you are running more than a 100 shot I would retard timing a few degrees
3. fuel puddling often occurs when you hit the rev limiter or spray too low, so yes a window switch will help
100 shot max, run copper plugs gapped at 0.035", NGK TR-6 or AWSF-22C. Retard timing 0-2 degrees, never more than stock timing. Don't even think of running nitrous with the stock platinum plugs.
You need an RPM window switch (3000-5800 rpm) and low fuel pressure safety switch set at 32 psi, in addition to the WOT switch, in my opinion. Also, a bottle heater is nice. You need a really good chassis to put all that torque to the pavement.
If you want to run more than a 100 shot, you will need a fuel pump and a dyno safe verified tune. Personally, I wouldn't do it.
Joe Lynch
I would tend to stay in the 150 and below range with a stock 99 motor. I would definetly upgrade the fuel pump on anything over a 100 shot though! If you decide on getting a kit, let me know, I got them in Stock and can give you a great deal!
Hey guys, What about a wet NX 75 shot on a 96 Cobra? Do I need to decrease timing or add a better fuel pump? Doesnt NX rate their kits at the wheels? So basically a 75 shot is like a 100 shot?
NX rates there jets in RWHP, so yes a NX 75 shot would be like a NOS/Zex/TNT/Edelbrock 100 shot. On your 96 cobra with only a 75 shot, I would not worry too much about the pump, couldnt hurt though! If you wanna play it safe you could pull 2 degrees when running the shot!
1 - 8 of 8 Posts
