I am having a problem with my 96 Vert running on the extreme upper end of the normal scale on the temp gauge. It has a new radiator and thermostat. Fan is working and even comes on sooner thanks to my chip by Dmann. The heater core is bad so it is bypassed right now. Any ideas guys??? I really need help on this one….I also ran seafoam through it yesterday to clean out the carbon.
mine did that for about a week after I flushed it it tends to get air trapped in the system and you just have to keep filling it. It is awful hot right now though at least here anyway
When it is cold(motor not outside) pull off the thermostat housing and thermostat and fill the opening in the intake with 50/50 mix until it is full then put back together and re-drive. Air gets trapped in the intake all the time!!
