Well, my original fan blade has given up the ghost and needs replacing. I am not interested in an electric unit (too big a project right now) Should I buy a foctory replacement fan and clutch or go with one of the "Flex Fans" without a clutch? Cooling is an issue with the S-trim so I need at least the same air flow of the factory fan. Anyone with some experice with this issue. Thanks all!
Go with the factory replacement. The flex fans are know for going south at unpredictable times.
Darin
i heard the PPI police clutch cools the car alot better. $99 for the clutch.
Yeah, what he said....I meant factory "type" replacement, as in fan & fan clutch.
Pedronius is right, though, go for the Police Fan Clutch and stock fan and you'll be OK.
I want to do the electric fan setup, but since the only real "kit" for the 5.0 is the Black Magic, I'll have to do some creative wiring/mounting myself. If you don't want to do that, do the Special Service Fan Clutch & fan.
Good luck!
