1 - 8 of 8 Posts
1/4”
Those caps are really meant more for vaccuum and not pressurized coolant. They will dry out and leak at some point. I’ve actually had one fail completely while driving spraying coolant everywhere.
Im using a piece of 1/4” heater hose with a bolt in the end. I did it before when I was stock and it lasted 20 years without failure after a vacuum cap let go. It’s ugly but reliable IMHO. I’ll pull it off and weld it one of these days when I have nothing else to work on.
Motor vehicle Automotive tire Hood Automotive design Tread
  • Like
Reactions: Wayne Waldrep
Discussion Starter · #4 ·
1/4”
Thanks. Probably will do the same. That’s the second cap that didn’t hold up.
USAF retired
Dorman sells caps that are made out of the same rubber as radiator hose material, I don't know the number for the 1/4" stuff though.
ive used the vacuum caps for years. change as needed. not really rocket science. small one, big one over it, fuel injection clamp.
or you can buy them new w/o the nipples.
whatever you want to do though. just don't hook it up to a vacuum port.
If you're not going to use the lines again..
remove the hose, pinch the port shut & TIG weld over it.
no leak guarantee
Weld/braze it closed and be done with it
1 - 8 of 8 Posts
