Im wanting to run 15"Centerline Convo wheels on my 97 Cobra,15x4 on the front and 15x10 on the rear.i know i will need to run a spacer set up with longer studs on the front,but what about the rear?the 15x10 wheels only have 5"back spacing,will they clear the rear disc brakes?Thanks Jim.
I believe Bob Cosby runs 15X8.5 5" BS on rear, and he clears brakes. Hope you are not lowered much, because you're going to stick out a lot with 15X10 5" BS. Most folks run 6-6.5" BS for rear 15X10. I ran for a little while some 15X10 Bogarts in rear with 6 1/2" BS for a perfect fit, but had to grind a little. Bogarts are thin, other heavier thicker wheels cause you to grind a little more.
5" is the most backspace you can get on a Convo Pro wheel. I have the 15x8.5's in back with the 5" backspace and they fit perfect. You can see them in the link in my sig. (the first pic is the best ;) )
