I wanna perform a compression test on my engine out of curiosity and I was looking at my Chiltons manual and it says you have to crank the engine with out turning on the ignition.....:confused: Can somebody give me some detailed instructions how I can perform this?
Best way is to buy a remote starter switch. They cost about $8.00 at Autozone. You'll hook it up to the starter.
Will
Alright, Ill do that. Are they hard to install?
No, not hard at all. Two alligator clips.
Thanks Guys. Now what kind of numbers should I be expecting from a 78k mile shortblock that has been beaten up pretty well?
Your other option is for instance pulling the fuse for the injectors. I'd say you'd be looking at 140-160 psi.
Thanks for all the replies guys. Ill be getting the compression tester and remote starter switch tommorow. Ill tell you how it turned out.
