1 - 11 of 11 Posts
I just got done redoing the lower intake gaskets. Either way, I'm going to have to redo that again, because it looks like oil is leaking from the rear of the engine where the lower intake mates with the block. I'm losing coolant somehow, and when I open the cap, I get bubbles coming up throught the overflow tank, and probably in the radiator, as well.
I suspect it's a bad headgasket because I'm having fuel pressure problems that could possibly have cause them to blow, as well. However, before I redid the lower intake gasket there was no loss of coolant, and no bubbles when I opened the radiator cap. The disappearing coolant does not seem to be entering the oil
How could I tell for certain if I have a blown cylinder head gasket?
Chris
Over-torqued the lower intake maybe? Pressurized coolant systems usually means blown gasket, oil or not. The bubbles usually will smell like exhaust or fuel..
I hve seen when a lower intake was installed once it lifted both heads and caused a leak but was visible in the oil after a couple houirs.
Super Moderator
And a compression test showing lower-than-normal compression on adjacent cylinders is almost a sure sign of a failed head gasket.
Coolant
Make sure the cooling system is properly bled. After I redid my lower intake gasket (I too suspected a head gasket problem), My cooling system bubbled for about 2 days till all the air got out of the system. A leak down test will also help troubleshoot the problem.
I talked to a mechanic buddy of mine who reccomended I take it to pep boys and let them do a hydrocarbon test. Will this be a sure-fire way of determining a bad head gasket?
chris
It failed the hydrocarbon test. The bubbles do smell like fuel. My only question is where is all the coolant going? If into the cylinders, why don't I see it in the oil or a white smokey exhaust?
Chris
1 - 11 of 11 Posts
