Decided to go a different direction. Im in the process of putting the top end of this motor together but thought I would list it for sale beforehand. I purchased everything new and it had less than 500 miles on it now. It has a complete trick flow top end kit- tf heads, cam, track heat intake, tf valve covers with welded an fittings, pushrods, lifters, mls head gaskets, arp head studs, arp intake studs, bbk 70mm egr spacer and 70mm bbk throttle body, bbk fuel pressure regulator. Its on a stand if you would like to look it over and could pull the pan if needed. Like to sale asap to free up some space in the garage. Located in rineyville, ky.
$2000. Would also take trades on foxbody suspension parts or wheels/bigs and littles - no prostars or draglites please.
