i am building a motor to hold me off until i can put together my built 351/turbo engine. i am on a budget and i want mid-low 13's(to keep up with those LS1 boys n/a) and a mid 12 on the bottle. do you think i can do that or a little better with this setup
Ported E7's
E303(i already have it so no chance of changing)
1.7 ratio RR's
Street Heat upper and lower
65MM Throttle Body
24lb injectors
Hooker SuperComp Long Tubes(already have)
3.73 gears(already have)
Pro 5.0 shifter(already have)
Off-Road H-Pipe(already have)
150 shot(already have)
also i have a SD car will i need to find a junkyard for a mass-air conversion?
What you have there looks good until you finish that 351. I'd convert to mass air...
Just an fyi, but w/ just the 150 shot you have a hi 11 sec car on slicks, so at minimum your in the low 11's once you add the ported heads & intake & cam.
