Hey I need help. I want to get to 11's Will this work
dart SR heads,1.72 rocker arms stock cam trick flow R 75mm tb 76mm mass air 1 3/4 long tubes 3.73 gears and about a 125 shot?? any advice greatful. I think this should get hi 11 to low 12's thanks
that cam gunna hurt you alot bc you arent letting any air/nitrous into the cylinders..even with the 1.72 it only gives it a bit more
its still going to get owned by the black biotch !!!
what you guys think about a cam ? how much gain going to a custom unit over the stocker ?
Discussion Starter · #7 ·
I now own the black bitch by a car an a half....................you better spray it next time
