I just installed some new TF TW heads, new lifters, pushrods, and Crane Cam Energizer 1.6 RR's. Well the rockers were to tight the first time and caused no compression. So I removed them and now when I push somewhat on the lifters there doesn't seem to be any give. I installed them somewhat dry. Except for the oil that was in them from shipping. Will this be ok until they pump themselves back up?
Please help. This is the last part I need to get my car going.
Thank you in advance.
Any give? Are the plungers up or down? If theyre up then adjust your rocker a quarter turn. If theyre down then? New lifters?
I haven't taken off the lower intake so I can't see them now. But they look to be up.
Go ahead and readjust them, a quarter turn should do it. Try a compression test after adjusting them and putting everything back together.
