Jim95LX said:
Does anyone have the part number for this piece?
I think I know what you're after..
You want the pump with the smaller impeller and fewer vanes for less drag. All of the '99-up GT water pumps use the same impeller as the "Cobra R pump".If you get the revised'01-present pump,then you'll need the newer pump pulley,or you'll need to machine a spacer for your old pulley to work..
JL
Actually I read somewhere is also had a larger bearing. This will help for heavy duty use. Was I mistaken and do the 01 and up pumps have the larger bearing?
This is for street/track use. Electric won't be an option. Thanks for your input though.
I thought the Meziere worked fine on the street. Actually I meant an Evans or an electric. I just put an Evans on mine.
