J.R. Granatelli said:
This is JR Granatelli. I hope you are happy with the product. I agree the double adjustable solids are a bit noise but it comes with the territory whenever you go solid mount. if perfect drivability is what you seek, then the weight jacker rear should work well. the sold lower as pictured above with the coilover conversion is nice too. I hope you are happy. What kind of rear shocks did you purchase?
Thanks for the input J.R.
I don't know a ton about suspension. So, I'm learning as I go.
I will be getting the coilovers on the front, and wanted to do the rear also.
I want to drop the car & want to get it sitting just right, & I'm not sure exactly what measurement
that will be. So i figured the coilovers would be nice that way.
The shocks recommended by JDSPerf. were the lakewood 50/50. He said their a drag shock, but work
with the coilover conversion. Is that correct?
Your title makes me think you've explained this before...,but,
What would be the differences in ride between the weight jackers and coil overs?
Street driving mostly, occasional track runs, 450 HP neighborhood.
I am ready to order the front coilover setup also. It will need to work
with the HP turbo kit.
What do you recommend for the front. Is there any options on spring
rate that would effect ride quality?
Post up or PM me - I'd like to know.
Thanks-
