I have bought the front and read coil over kits, and was wondering about using the fronts with your caster/camber plates....basically what I understand is the bearing cover replaces the stepped 7/8 spacer underneath the C/C plate, and the stepped spacer is installed upside down, with the guide through the C/C plate on the top then the nut....does that sound right?
Love using your products and have had great success with everything! Keep up the good work!
