1 - 1 of 1 Posts
I just purchased a r-trim blower with a 74 tooth crank and a 29 tooth blower pulley and i have a few questions.Can i run a standard serpentine belt to run my alternator and water pump or do i have to change my configuration.I has a s-trim with a 2.75 pulley that made 14 lbs. with a 10 rib setup.Should i just use my serpentine setup?What kind of boost would the r-trim make with either the cog or serp. setup.I would greatly appreciate any help or pics.
1 - 1 of 1 Posts
