I just did the Self-Test jumper trick, and it brought up a code 33 in both engine off and engine on modes.
Code 33 reads in my Haynes manual "EGR valve opening not detected".
I ran the car until "normal" operating temperatures were reached (even idled it at 2K RPM for 2 minutes).
I do have a 180 degree thermostat, and my car usually (especially now that it's cold out) doesn't get much above the N in NORMAL.
Could the thermostat be giving me this code, or is it likely something else? Any suggestions?
Thanks,
IJ
Discussion Starter #2
OK, took it for a hard drive and re-ran all the tests:
KOEO = 33
Continuous Memory Code = 33
KOER = 11 (good)
Cylinder Balance Test = 90 (good)
BTW: This is awesome! :) The testing went really easy, although a little different than the write-up in the tech articles. That write-up could use some editing, it's confusing. EX: it describes the KEOR twice in a row (slightly differently), and (for my car anyways) the cylinder balance test hovered from 1,600-1,700 RPM instead of the 1,000 RPM described. It also doesn't say where the self-test harness is! Also, using a paperclip is alot easier than fabricating some wire and crimping connectors on.
Anyone?
IJ
More than likely, the EGR valve position sensor is bad. That's the plastic thing bolted to the actual EGR valve, that has a small harness plugged into it.
