I bought a set of aftermarket valve covers, these covers are not higher than the stock ones but both of the oil breather holes are on the side closest to the firewall. the breather on the passenger side of the motor does not clear the upper manifold. does anyone make a "low profile" breather??
I have been waiting for someone to ask this question. I have the same problem and need a short breather.
i have an idea.......would running a small rubber hose from the valve cover to the pcv valve work??? this would solve all clearance issues because the hose is flexable and could easily be bent around the manifold.......simple and cheap fix....will it work?
