You may want to put a mechanics stethoscope against the bell housing while someone pushes the clutch to verify if the noise is from that area.
Do the same with the brackets which the pedal mounts on. Verify the bracket mounting bolts are tight.
Do you have the bracket installed in the area of the fuse block which secures the clutch cable in to the frame rail? Is it loose?
Do you have a clutch cable length adjuster against the firewall and is it moving around?
