Have a re occurring issue with my 93 fox. When things are warmed up I get a pop when the clutch pedal is half way down on its stroke to the floor. If I push slowly on the pedal it is ok. Once cooled off it goes away. It has done it with the last trans (astro a5) and centerforce clutch setup. On my 3rd maximum motorsports cable thinking it was something with that. Current setup is brand new tremec tkx and mcleod rst twin disk clutch and new fork. I have long tubes on car and the header tube gets close to the cable. I have insulated the cable with a dei exo sleeve as well as header wrap and an aluminum sleeve around the cable. Also wrapped the header tube near the cable. IN addition I installed a small phenolic spacer from maximum motorsports at the end of the cable where it enters the QuickTime bellhousing. Cable is brand new and I am using the maximum motorsports firewall adjuster and quadrant. The pop sound seems like it's under the car but maybe it's at the pedal and being amplified down the cable to the fork? I was going to try new clutch pedal bushings next?. The car is well built and with very good components . Maximum motorsports says they haven't heard of this. It will do it with the engine running as well as when the engine is off but only once up to a higher temp. After cooldown its silent. I am at a loss here as to what is going on
