When i press down my clutch pedal it feels sloppy not smooth when the car is on. But when i shut the car off and press the clutch its smooth. Also when i let the clutch all the way out i hear a pop sometimes. What is going on? Also it is hard to get it into 1st and reverse sometimes from a dead stop, but if im rolling slightly it will go into gear perfectly fine. The clutch was replaced in september with a McCleod Dual Friction and the clutch cable was replaced with a stock cable from ford. The car has 85k miles and the new T-56 has about 5k on it. Do i need to replace the cable? or can it be the quadrent? or something else?
