Should there be anything i should be aware of when doing this clutch install. first take the stock one out and putting the aftermarket one back in. Is there any tips on doing this or is it just simple thanks guys need some advice thanks
Formerly known as 302Quest
i have some tips, the top 2 bell housing bolts are gonna be a *****
take them out first..
make sure you have good sockets. you don't want one splitting in half and stripping all the heads on the bolts..
get a new pilot bearing
take your time
have patience with the 3 starter bolts, their a *****.
DO NOT forget to have your flywheel resurfaced.
use a torque wrench
~J
thanks alot BLack Your a good man Thanks alot and thats all i need i guess sounds like . Thanks Again . Zach~
no problem, Bob Cosby put up a Transmission install FAQ i'll see if i can locate it for ya, because i was the one who asked.. :D
~J
P.S. and here it is Transmission Drop
