I'm looking for info on adjusting the physical clutch pedal height. Has anyone done this, is there a mechanism to do it or is it even possible? I want to lower the clutch closer to the floor... not the engagement location, the physical pedal height.
Thanks for any help,
Rich Allaire
'99 GT - Chrome Yellow
All stock but in the process of being modified
Send a PM to Blown46Cobra. I just installed an adjuster he is selling which will allow you to adjust the pedal height. For example, you can easily adjust your pedal to be the same height as the brake pedal. You will NEED to have an aftermarket adjustable quadrant for this to work. I like the UPR pieces with stock cable. My NEXT Mustang will get one of these the first week (along with a shifter, gears and K&N).
