I replaced the plugs recently and went out for a drive. When I rode it hard just for a little while, I developed a bad miss. I went to do a compression test and three of the plugs had the gap completely closed, 2, 6 and 7, not that it matters.
What would cause that to happen (and no I didn't drop any and was very careful installing them)? Piston cantacting them? Something rolling around in there?
They are 3924's and I have twisted wedge heads.
On aircraft engines that is called a shorted secondary, usually caused by detonation, what is your timing? what kind of fuel? Could the mixture be lean? I would get it on a dyno soon, you may already have piston damage.
I'd definitely say it was caused by detonation. I've seen that before on blown engines especially. Actually one time me and a buddy were racing a firebird on the interstate and had that happen. Pulled over at a gas station and started pulling plugs until we found it. Actually broke the porcelain around the center electrode. He ended up blowing the top of a piston into the oil pan with the skirt still on the rod......
I've seen melted plugs while running nitrous before and this wasn't the case here. They were physically closed as if you had dropped them.
I had the washers in place so that wasn't the problem. I'll try doubling the washers and see if that helps.
