i have flushed it twice and it did no good:mad: . its the go-dan radiator from pep boys. almost two years old. it has the white sutty looking hard deposits on the inside. what do? do they make anything other than rad. flush. what about acid? any ideas?
take it to a radiator shop and have them ROD it out. They can do this in about a hour and its like 30 or so dollars. If you take just the radiator to them.
Allen
Did you use tap water in it? Tap water leaves deposits. Next time use distilled water and coolant and no problems. If you did use distilled water then disregard everything i just said.
Discussion Starter · #4 ·
well that sucks. i didnt use distilled water i used it right out of the tap. now if they rod it out, is that were they take the tanks off the sides? or do they just use a chemical. the rad is cooling the car well i just dont want the deposits to be a problem in the future. thanks.
