I have a pair of used GT-40X aluminum heads that I need to clean up. Where I've been having some difficulty is in the combustion chamber where there's some carbon build-up. What's the best way to clean up the combustion chambers? I obviously don't want to use anything especially abrasive and scratch up the chambers.Is there a solvent that works well?
TIA
wouldn't hot tanking them do the trick?
Thanks for the replies guys.
Out of curiousity, are there any problems associated with hot tanking aluminum heads? If not, how much does the process generally run?
yeah i didn't read the aluminum part...
i don't think your supposed to hot tank aluminum stuff.
but i really have no clue.
NO
you cant hot tank aluminum heads, it will eat the aluminum. call a machine shop, they will tell you they use a "cleaner" on the heads.
