Ok.....So...Basically I can either do 4.10's (keep in mind it has a Vortech) or get some Eibach Pro-Kit Springs. So let me know what you think.
Thanks,
Mike
Are you still running a stock suspension? I don't know how you keep that car on the road with all that power. Forget the springs and start with some high quality lower control arms and subframe connectors. Remove the quad shocks. Then get some CC plates and add good springs and shocks/struts. You'll find it a lot easier to make use of all the power you've got if you get a suspension that's up to the task.
Assuming you've got about $200 bucks to spend on parts, get a spring kit. 4.10s will just make it easier to overdrive the stock suspension.
