1 - 1 of 1 Posts
I just started my 96 mustang cobra, went to leave work and after about 5-10min the Check Engine Light comes on, and stays on now after I got home and if I turn the car on again it's still on. I know on Chrysler's you can turn the ignition key on and off 3 times then the Check Engine light will flash which corresponds to a code. Does Ford have any way to check without a scanner? Or is there any things I can try? I wonder if its just something simple, because it only has 28k miles and before the ABS light came on and it was just low on brake fluid.
1 - 1 of 1 Posts
