What else can be wrong, the old speedo gear was shredded.
check the connections on te V.S.S. plug again, do you have the speedcal also if so check the dip switches
Would I have to check if there is power going to the V.S.S plug? Is this the plug connected to the speedo gear?
I would have to look again I believe the gear depending on how fast its turning sends signal through that connnector thier are some people on here that could tell you how it works I cannot adn do not want to give you bad advice. I do know that the plug and gear work together somehow
