Ok, I changed my fuel pump because it went bad and now my fuel gauge reads completely full all the time. I know it's not full so what's the deal? HELP!!! Thanks
You must have messed with the fuel sending unit when installing the fuel pump.
The fuel sending unit is in the gas tank and from your description I suspect when you installed the fuel pump it wasn't installed in the proper orientation and the float is hanging up on the bracket or wiring.
You need to drop the tank again and inspect.
Sorry.
