Depends on which ring, top or second and maybe even the brand....Did you lose the insert that came with the rings? Normally there is a dot that indicates the top side of the ring....James
I've got the plasma moly Sealed Power file fit rings. The instructions stated that the dot stamped into the ring goes up. If no dot, it can go either way.
Other brands or models may be different.
insert??? there is no paperwork but I am assuming the direction is important I wil look for dots on the rings
anybody knwo for sure if the chamfer goes up or down??
