can you use the edelbrock electric choke kit on this carburetor? They appear to be virtually identical. This carb has EGR vacuum port and all of the stuff needed to hook up all of my emissions stuff, so if I can use the electric choke, I am going to be really happy.
I also need to know where to get the idle dash-pot for these carburetors. My stock one is not going to live much longer.
Discussion Starter · #2 ·
Yes you can transfer parts. The Edelbrock series carbs were actually designed by carter. Summit or Jegs also sells the idle compensator you're talking about- it's about $60 though.
-later
USAF retired
I believe you can swap parts as well. I checked into this when I had my old 52 F1 with a AFB carb. The Carter people said the only differerence was their carbs had polished screw heads on the top. This was 4 years ago, they may have other differences now.
David
Discussion Starter · #5 ·
sweet, that means I can have an emissions legal stroker 351-W. I needed a 750 carb, and it looks like I finally found it.
