Alright so I just bought this kit and I am wondering what else I need.
I have a 70mm tb
73 maf
30lb injectors
Stock fuel pump with vortech t rex out tank fuel pump
Ported gt40p heads
Pro products upper and lower manifold
Biggest cam ford makes I think the z or x whatever is bigger
1.7 r.r.
Long tube bbk headers
Off road X pipe
Mac cats
Stock rear gears
Stock fuel rail
Holly adj. Fuel reg
Msd 6al
Msd coil
So what do I need and what do I need to upgrade? Thanks
At least 42# injectors
maybe a 255 in tank - not sure how that external will pull through a OE pump...
Engine management system or some sort of tuning device.
Sell your headers, exhaust, cam, and injectors. A stock cam would be preferable to an X or Z cam.
I have this kit!you will need at least 42lb injectors and a protube! i would put a 255 intank and the external pump right inline! with this you can ditch the fmu to 12-14lbs with the engine setup,i would however make sure to get a good TUNE! the X 303 however it has a 107/117 it probably will work but i would get a custom cam or f-303, i run the stock cam and it works great imade 535rwhp 622 tq,with dart sr iron heads 1.72 rrand a gt-40 @15lbs,and no fmu!as for the rear gears i would upgrade to 3.27 sounds great and happy boosting:leghump:
