I have a large amount of early carburetors. Below is a list of some of the carbs I have. Message me here or email me at [email protected] . Thanks guys!
$100 each core! Will make a deal for bulk purchase!!!
1-1960's 1904 Holley 1 barrel
2- Holley 2 barrel 6r-1258-3
3-Rockester GM Quadrajet electric choke 4 barrel 7058230 0463
4-Holley 4 barrel eck-9510-h-list-1074
5-Motorcraft 2 barrel electric choke 7u apa
6-WORKING 1963 1 barrel Falcon Autolite c30 f b a2md
7-Holley 2 barrel electric choke list-6221-2 3166
8-GOOD 1965 Autolite Ford 2 barrel c52fha5ab
9-Quadrajet 4 barrel
10-GOOD but missing float 1960 Ford Autolite 2 barrel
11- 1982 v6 Motorcraft F2-2150 (Jeep/AMC/Eagle/Pacer) with electric choke PAC2 e2be va
Standard Plus ss-581 Starter switch $20
Delco A/C relay #15-844 1966-67-68-69-70-71-72 CAMARO SS NOVA Z28 CHEVELLE 442 GS A/C FAN RELAY $15
Standard ps-60 Oil pressure switch $13
Standard ds-70 Dimer switch $12
Motorcraft db-187-1 $25
Standard dr-318 $1471-72 Pontiac Thermostat housing water cooler neck $25
77-79 Cadillac rear trunk logo #1716264 $109
Standard RV-10 Ballast Resistor $10
AC Delco 15-2147 A/C cutoff switch $17
Motorcraft ce-106 (5 of these) $18
77-79 Ford 30-132 Choke pull off $15
Anco 62-01 Windshield washer pump $17
Ford d5uz-4255-a $19.99
Holley GM Float 216-2 $7
Standard dr-318 Rotor $12
Standard fd 8006 $12.75
Onan 166-0820 $88
Wizard voltage regulator $65
ECCO Back up alarm 510 $26
Ford Power window gear kit $17.50
Standard vr-166 Voltage $24.99
BAC A LARM model 230 $18.50
Ford e8vy-1130-c center cap $115
Ball and roller LM-104949 $12
Onan 166-0820 $88
