Cougar232 said:
I do not know how to advance the timing on it. is it possible to even do this to that year.
Uh, any year engine you should be able to advance or retard teh timing, unless it is a distributorless ignition. Also, if it is computer-equipped, the 'puter may offset anything that you change from base.
When you talk about timing, there are different types - base, vacuum, advance, and total.
I *HIGHLY* suggest that you pick up a Chiltons or Haynes book. It outlines many basic procedures (such as adjusting timing) that can be done to a vehicle.
