I have a 700 CFM, double pumper mechanical secondary carb. Will I be able to drive it if only the front 2 jets work?
yeah, the back venturies just open up after a certain % of throttle. id get it fixed.. it will feel like a dog and try not to get on it too much so as not to run lean. you will be able to drive.. more than likely you basicly have a 300 two barrel in a 600 4 barrel body.
no.....not really, the secondaries open progressively or in unisyn with the primaries on a mech second double pumper........they either have a cam opening or 1:1
it will run like ****, but will run if you are lucky
