For the last year or so I've had my EGR vacume hose pluged to stop my check engine light from flashing. Now my car has begun running terrible. It sputters at low rpm.
When I disconect the battery cable for a while and re-attach it, the car runs like a lexus. So, obviously it's sensor or somthing. I pulled the following codes:
KOEO Codes:
CODE: 31 (KOEO) - EVP circuit below minimum voltage
KOER Codes:
CODE: 21 (KOEO) - ECT out of Self-Test range
CODE: 41 (KOER) - Right HEGO Lean
CODE: 91 (KOER) - Left HEGO Lean
These code seem to point to somthing making my engine run lean which seems like it could account for my sputtering. Anybody have any ideas?
Codes
The EVP code is related to the EGR solenoid. That is the electrical portion of the sensor. The ECT code is related to the Coolant Temp sensor. I would replace the coolant temp sensor and the Egr Solenoid. I think the O2 codes are related to the other codes. Replace the two parts and clear the codes.
I've got rid of those last 3 codes by cleaning the hell out of the egr valve. However I now get the following code:
CODE: 46 (KOER) - No Thermactor Air Bypass
My car was running much better again after I had reset my computer, but yet again it is missing/sputtering. Anybody have any ideas?
