Floor it through the gears some times the car will just stop but still be running. I have H/C/I full exhaust MSD btm MSD cap and rotor MSD coil and a novi 1220. I don't have a clue what it can be. Fells like the car hit a wall.
Member
Do you mean that the engine cant hit higher rpms? Like it runs strong through the lower rpms and then it wont rev past 4,500-5,000?
Dosen't happen all the time. I will run some one and the car will fall on it's face hard. All I have for fuel is 94 octane stock rails stock lines with a 255 pump and fuel regulator. Think it could be the fuel filter? The car will run in the 4,500-5,000 rpm no problem. Just the odd time it will cut out when I am on it hard. My setup is Edelbrock 2 02 heads RPM intak 70mm TB X Cam Ford Racing 42's with 80mm mass air full exhaust catted with a Novi 1220 UPR power pipe MSD BTM MSD coil and wires. The car is making 410 foot pounds of torque and 450 rear wheel horespower.
Member
Oh okay. My buddy is having the problem i described. So yours sounds like something electrical is loosing connection. I coud be wrong but thats what it sounds like.
ya id check the msd box. I had a similar problem were it rpms would drop and it would die. Turned out the msd was bad
Discussion Starter · #6 ·
Thanks. Trying to think if it did that before i had a MSD box. Really didn't want MSD but my tuner made me buy one.
