1 - 11 of 11 Posts
I am running TFS 1 cam, performer heads/intake, 24#ers, 73mm mass air, and the car kind of idles, I can sometimes get it to settle down to around 1000......but EVERY time when i am driving and I push in the clutch, it instantly dies......I know my TPS is screwed, but what else could it be? I doubt TPS would effect it that much
Also, I have tried it with/without IAC plate......same results
Are the 24's calibrated to the 73mm?
calibrated ? I have the 24# sampling tube in the mass air if thats what you are asking......
Banned
reset your tps voltage to between .94-.98 (or replace it) then see what happens, one thing at a time. Do you have a check engine light?
are u sure its not a vacuum leak?
or just open up the TB more when it's at idel...just twist the little screw on the bottom of the TB to open it up a bit...I had a similar problem and that helps...BTW also make sure your TPS is fine.
Discussion Starter · #7 ·
yah thats the thing, in my other post, my TPS is so screwed.....no matter WHAT position of it, PLUS i tried adjusting the idle set screw, the voltage will NOT go below 2.6 at any point
right adjsuting that screw can screw up your idle. Follow the idle reset procedure in the tech section.
I think in your other post you said you tried multiple tps's... maybe you have a bad ground or a short somewhere?
What are you guys talking about...not adjusting the idel set screw??? you can and you definately should...there should be a mark on the screw that gives you a range sort of a norm on how far you can go either way...Now since he has a bigger cam he needs to do that...That is partially why his car is dying out...set the TPS and adjust the screw so that the car don't die at idle.
Discussion Starter · #11 ·
You have to realize this........no matter WHERE the TPS is adjusted, or WHERE the idle set screw is.....it wont go below 2.6 volts, which means the problem is somewhere else......and I dont think its the TPS cause i have tried 3 of them now......thanks for the ideas, but it cant be that
1 - 11 of 11 Posts
