im so freakin pissed, just slides right in my azz. whats the tranny hitting, what can i do. this is a t5 trans and lakewood bell.
3/8" to go.
Super Moderator
Hook up the clutch cable and have a friend step on the pedal while you slide the trans the rest of the way in. That's all it is.
ok clutch cable is hooked up, ill go try that thanks.
The clutch should solve the problem, but if it doesn't do not use the bolts to pull it into the block. This can lead to damage to the motor and tranny.
Discussion Starter · #5 ·
well thanks but, i messed up last nite when the tranny slipped.
i think im going to wait to get back from wfc5 now. oh well
alot less stress on trying to get the car ready for friday thanks chad
