1 - 8 of 8 Posts
John,
I find on the tight-packed clutches I have to grind the shaft a bit some times to make them fit. Not a big deal, but an issue I forgot to warn you about...
Also, if the diff has sat out dry since (what, 1986? LOL!) you may and should squirt/flood the frictions with oil, as they will be dry as a bone and pop/chatter like no other (trust me :D).
Good luck!
Chris
yea, I had to grind mine a bit when I installed an Auburn.
1 - 8 of 8 Posts
