1 - 1 of 1 Posts
Hi
I am new to the forum and need help with identifying a cam.
Numbers on the back of the cam are TFS 5140 001 4062YG.
I know its a Trick Flow Track Max But what i dont know is what stage.
It is supposed to be .243/ .248 @ .050 duration and .568/ .577 lift with 112 Degree lobe seperation.
None of the stage cams have any of these numbers. The closest i can find is stage 3 but not sure because the lobe seperation on it is 110 degrees.
Also not sure if this is a grind # HR112 +4
Any help would be greatly appriciated.
1 - 1 of 1 Posts
