Does anyone know if there is suppose to be a spacer in between the cam gear and the cam? I am using a gear drive. When I tighten up the cam gear it binds up and the cam won't turn then. I don't remember seeing one when I took it apart with the chain.:mad: This is the only thing stopping me from getting this back together.
Are you using the correct bolts on the thrust plate? They have a very short head so they don't hit the back of the cam gear. You don't need a spacer with a chain set-up but not sure with gear drive.
Bill
