1 - 8 of 8 Posts
Just got my rebuilt c4 back installed.
As it is
Park=Park
Reverse =reverse
Neutral = reverse
1st =nothing... Neutral
2nd = 2nd
3rd= nothing
Any places to look 1st??
If you disconnect the shift linkage and shift it at the trans, can you feel it click into each gear? What shifter are you running?
Discussion Starter · #6 ·
Ok I'll try re doing that.. it was all reinstalled just how it was removed. I've had the shifter for years with this trans.
Discussion Starter · #8 ·
I just got it... the builder put the transbrake solenoid
Piston in backwards.
It goes solenoid >piston>spring
he had it solenoid >spring>piston.
Maybe this helps someone in the future.
1 - 8 of 8 Posts
