Green9550
I have almost the same combination as you.. Except mine may be a little milder... I have stock shortblock,, AFR 165's, cobra 1.7 roller rockers, stock cam, cobra intake (box stock) , 65 mm throttle body, C & L 76mm mass air kit , Mac equal length shorties, h pipe, mac mufflers, Precision Industries stallion 3200 convertor, baumuan shift kit (still does not shift 2-3 or under light throttle as hard as i would like), still have stock 3.27 gears, nitto drag radials (275/50/15) , draglites, etc... I am a 360 lb driver in a full weight 95 gt.. (only draglites and a removed front sway bar make it any lighter).... Last week i ran a 12.32 @ 111mph with a 1.71 sixty foot on the nittos with a 100 horse dry NOS kit.. I have not driven it yet on motor but it is a bogs some when my 200 lb lighter wife drove it on "just the motor" it ran 13.60 @ 102.5 with a miserable 2.00 sixty.. (bogs on nittos with the 3.27 gear on motor).. I believe the car has more et left if i can ge a chip burned to get rid of the damn 5500 rev limiter... It feels like it is still pulling strong when you have to shift in order to keep from bumping the rev limiter.. I believe with my wife (much lighter driver it will run 12.0's with her in the drivers seat..) I plan on gettting it on the dyno in a few days to get some numbers and do some tuning (mainly timing and fuel pressure).. BTW, if you dont mind me asking how much timing can you run.. IF i run more than 11 degrees it pings when it goes into drive on a warm day even with 93 octane in the tank???? I pull out 4 degrees of timing when i spray the car.. I am currently debating wether or not to put 3.73 's in it.. I am afraid that i will be against the rpm limiter when i spray without getting something to move the dang 5500 rev limiter up!
BigT
BigT
