1 - 1 of 1 Posts
Hi,
I'm installing a Baer touring kit in the rear, and ran into a snag. I bought Moser 28-spline axles, hoping they were a perfect stock replacement.
Unfortunatly, I've discovered that the c-clips sits VERY loose on the axle end. It will slide right off w/ just gravity when the axle is turned.
I took the rubber grommets off the old axles, and put them on the new ones, and it helped, marginally.
I still think it's too loose to adequately retain the axle. Do C-Clips come in varying thicknesses?
*EDIT*
Well, it doesn't matter, actually. The differential pin is thick enough, that there is no play in/out. So, I'm satisfied.
1 - 1 of 1 Posts
