I want to upgrade my stereo in my 97 GT with The Mach 460and realize that I have to either re-wire the speakers or by-pass the factory amps to use factory wiring. I did a search but got confused on the actual location(s) for by-passing the amps. How many locations are there to by-pass? How many adapters do I need? Where is the best place for the cross overs that come with my new speakers? Thanks for any help you can provide.
You have a couple options for upgrading your mach system
1)Gut the whole system and install new stuff (best option)
2)Install new head unit and leave the rest of the system alone. Uses an adaptor to set the levels between the HU and stock amps.
Just running new speakers with the rest of the equipment stock usually sounds pretty bad.
