· Registered
1994, Ford Mustang Gt
Recently my 94 Gt has been making a weird buzzing sound. The sound, sounds like it’s coming behind the radio/center vents/dash. It has a different pitch depending on how fast i’m going (loudest being idle). Also when i’m at a light and pressing my brakes, the buzzing sound seems to be louder and same goes for when I turn on my headlights and ac. I have no clue what this could be, maybe a bad relay. I’m not sure, please help. Thank You.
· Registered
It could be a vacuum leak at the hvac controls. You could unplug the vacuum source under the hood on the vacuum tree to see if it goes away.
  • Like
Reactions: Bentley
· Registered
The vacuum tree is over by the brake booster. There will be a small vacuum line from it running along the firewall and will enter into the firewall by the A/C and heater core connections.
unplug it at the vacuum tree.
Be careful, it’s probably brittle.
