1 - 9 of 9 Posts
Are there bulbs in the back of the fog lights that you can replace or do you have to buy the whole light? If bulbs, what kind and where do you get em? Thanks.
Just crawl under and unhook the wire harness from back of light. Grab the base of bulb and give it a half turn, it should then pull straight out. Better get use to changing them, they tend to burn out frequently.
I need to find one that is brighter and lasts longer. You're right about those things burning out a lot. I've changed mine at least 3 times a piece.
I X L
95 Cobra hardtop convertible
Guys, are the GT AND Cobra lights changed that easy??
I noticed the other day on the way to work, one was burnt out, but just flipped the power switch off, and haven't crawled on the cold frozen ground to look at it any closer...
It should take less then five minutes, and thats if you dont have any arms.
Cool, I have both arms, so I'll try to beat that time...;)
Thanks...
If you want a brighter bulb, get the 885 bulbs. They are MUCH brighter than whatever the stock bulbs are. I have been running them for a few years now and the difference is amazing. The first time I turned on my foglights with those bulbs in I thought I turned on the headlights.....:D
1 - 9 of 9 Posts
