I'm swapping out my old tired stock GT rear disk brakes for a new Bullitt (94-98 Cobra) set up. Included in my kit are the larger disks, calipers, dust shields, anti-moan bracket, and mounting bracket for the caliper.
From the looks of it and when I compare the parts, it appears that I will have to use the new mounting bracket for the caliper because the disk is a little larger at 11.65 compared to my stock 10 inch rotor.
In order to swap out this bracket, it appears that I will need to pull my axles. Is this correct? :confused:
got everything on, swapped the brackets and they certainly stop like crazy!!! now i need to do the fronts.
